Folgendes Backup Script dient als Beispiel wie eine einfache Datensicherung eingerichtet werden kann. Es ersetzt keine professionelle Lösung!
Auf eigene Gefahr
Dieses Script löscht Dateien! Bitte auf eigene Gefahr anwenden! synetics übernimmt weder Garantie noch Support und schließt eine Haftung für Folgeschäden aus.
#!/bin/bash
#### System requirements
#### The following tools need to be installed:
### mysql - for the MySQL database backup
### tar - for the file backup
### ncftp - for the FTP file copy
### samba-common - For the CIFS file copy
### cifs-utils - For the CIFS file copy
### Debian install example:
### apt-get install samba-common cifs-utils ncftp mysql-client tar
## Global configuration options
glob_machine="idoitserver" #Machine name to label backup files
2015-12-12_1755)
glob_path="/tmp/backup/${glob_machine}" #Specify local backup path
glob_delete=0 #Delete local files immediately after CIFS or FTP copy?
## Database backup configuration
backup_database=1 #Database backup enabled?
db_user="" #MySQL username
db_pass="" #MySQL password
db_host="127.0.0.1" #MySQL host
db_names="idoit_system idoit_data" #Database names to backup separated with space
## File backup configuration
backup_file=1 #File backup enabled?
file_files="/var/www" #File paths to backup separated with space
## FTP configuration
copy_ftp=0 #Copy files to FTP server?
ftp_user="" #FTP username
ftp_pass="" #FTP password
ftp_host="" #FTP servername or IP address
ftp_path="/backup/path" #Backup path on FTP server
## CIFS configuration
copy_cifs=0 #Copy files to CIFS Share?
cifs_user="" #CIFS username
cifs_pass="" #CIFS pass
cifs_path="//cifs/file/share/path" #CIFS backup path
cifs_mount="/tmp/backup/cifs_mnt" #CIFS share mount point
cifs_domain="" #CIFS domain name
## Old files deletion
delete_file=0 #Delete old local backups?
delete_file_age=7 #Delete local backups older than x days
delete_cifs=0 #Delete old cifs backups?
delete_cifs_age=7 #Delete cifs backups older than x days
#-------------------------- Stop editing here --------------------------
mkdir -p ${glob_path}
umask 177
#Mount CIFS share
if [ $copy_cifs -eq 1 ];
then
echo "Mounting CIFS share ${cifs_path} to ${cifs_mount}"
mkdir -p ${cifs_mount}
{cifs_pass}
fi
#Database backup
if [ $backup_database -eq 1 ];
then
for i in ${db_names}
do
if [ -n "$i" ];
then
tmp_sqlfile=${glob_path}/${glob_machine}__${i}__${glob_date}.sql
echo "Dumping MYSQL database ${i} to file ${tmp_sqlfile}"
{tmp_sqlfile}
if [ $copy_ftp -eq 1 ];
then
echo "Copying ${tmp_sqlfile} to FTP server ${ftp_host}"
/usr/bin/ncftpput -u ${ftp_user} -p ${ftp_pass} ${ftp_host} ${ftp_path} ${tmp_sqlfile}
fi
then
echo "Copying ${tmp_sqlfile} to CIFS share ${cifs_path}"
cp -f ${tmp_sqlfile} ${cifs_mount}
fi
if [ $glob_delete -eq 1 ];
then
echo "Immediately deleting file ${tmp_sqlfile}"
rm -f ${tmp_sqlfile}
fi
fi
done
fi
#File backup
if [ $backup_file -eq 1 ];
then
j=1
for i in ${file_files}
do
if [ -n "$i" ];
then
tmp_filesfile=${glob_path}/${glob_machine}__${j}__${glob_date}.tar.gz
echo "Packing files ${i} to ${tmp_filesfile}"
tar czf ${tmp_filesfile} $i
j=$((j + 1))
then
echo "Copying ${tmp_filesfile} to FTp server ${ftp_host}"
{tmp_filesfile}
fi
then
echo "Copying ${tmp_filesfile} to CIFS share ${cifs_path}"
cp -f ${tmp_filesfile} ${cifs_mount}
fi
then
echo "Immediately deleting file ${tmp_filesfile}"
rm -f ${tmp_filesfile}
fi
fi
done
fi
#old backup deletion
if [ $delete_file -eq 1 ];
then
echo "Deleting files older than ${delete_file_age} days in ${glob_path}"
find ${glob_path} -maxdepth 1 -mtime +${delete_file_age} -exec rm {} \;
fi
then
if [ $delete_cifs -eq 1 ];
then
echo "Deleting files older than ${delete_cifs_age} days on CIFS share ${cifs_mount}"
find ${cifs_mount} -maxdepth 1 -mtime +${delete_cifs_age} -exec rm {} \;
fi
fi
#Not implemented so far
#if [ $copy_ftp -eq 1 ];
#then
#fi
#Umount CIFS share
then
echo "umounting CIFS share ${cifs_mount}"
umount ${cifs_mount}
fi
