QR Code#
Configure the QR code settings in this dialog. You can choose whether the QR code should contain the primary access URL of objects as content or whether a global definition should be used. Additionally, you can decide what happens when you click on a displayed QR code. → READ MORE
QR Code
Modifying variables#
Since i-doit 39 you can modify the variables of the global definition with modifiers, for example to use them in a URL. Append the modifier to the variable name with a pipe character, for example %hostname|lower%. Several modifiers can be combined and are applied from left to right, for example %hostname|lower|encode%.
Modifier Effect
encode Applies URL encoding (spaces become +)
raw-encode Applies raw URL encoding according to RFC 3986 (spaces become %20)
lower Converts the value to lower case
upper Converts the value to upper case
slug Converts the value to a URL friendly form (slug)
The same modifiers are available for the URL in the category Access.
