Single Sign On (SSO)#
The authentication via Single Sign On (SSO) is well suited for an automated sign on to i-doit within an intranet.
This article was last checked for i-doit version 1.17.2
This tutorial does not work anymore with Debian 11 because the Apache2 module mod_auth_kerb is not available anymore.
You should use GSSAPI instead.
Requirements and Assumptions
The following conditions are the basis of this article:
- i-doit is installed on a GNU/Linux system
- An Active Directory (AD) on Windows Server 2008/2012 is used for the authentication.
This article describes how Single Sign On (SSO) is set up in an Apache web server with auth_kerb.
Case sensitivity
Special attention needs to be paid to upper and lower case letters in the configuration.
Configure Active Directory (AD)#
In AD a user is generated for the SSO access. Example:
- Server name of i-doit: idoit.mydomain.local
- AD domain: addomain.local
- SSO user: ssouser
- Password: password
A keytab file is generated on an AD domain controller using the admin user with help of the ktpass utilities.
1 |
The generated krb5.keytab file is then copied to the i-doit server at /etc/krb5.keytab.
Afterwards, Active Directory Users and Computers is opened (adsiedit.msc). At View the Advanced Features option is activated. Now the SSO user object is opened. Search for the values userPrincipalName and servicePrincipalName in the Attribute Editor tab. In both cases exactly one entry with the value HTTP/idoit.mydomain.local needs to be set.
Configure Apache Webserver#
The module auth_kerb is required for the Apache web server.
1 2 3 4 5 6 7 8 |
Now the configuration for Kerberos will be written (replace dc.mydomain.local by the domain controller): # cat /etc/krb5.conf [libdefaults] default_realm = ADDOMAIN.LOCAL
1 2 3 4 5 6 7 8 9 10 |
Execute the following command to test the configuration:
1 |
The password of the SSO user is requested. With the command
1 |
you can check whether or not a valid ticket exists.
Subsequently, the Apache configuration for the VHost at which i-doit is accessible is supplemented within the Directory directive:
1 2 3 4 5 6 7 8 9 |
In order to apply the changes the Apache web server needs to be restarted:
1 2 |
Configure i-doit#
From version 1.5 on SSO can be configured via the web GUI of i-doit. The corresponding settings can be found at Administration → System settings. There SSO needs to be activated.
Browser Client-side Configuration#
Lastly, each browser needs to be configured to automatically use SSO.
Microsoft Internet Explorer (IE)#
The i-doit server needs to be added to the local intranet sites in the IE settings. After this, the item Automatic logon with current username and password has to be enabled under User Authentication within the Custom level option. Furthermore, make sure that you activate the option Integrated Windowa authentication in the Advanced tab of the Internet options.
Mozilla Firefox and Google Chrome#
SSO is also possible for these browsers. Extensive information about the configuration can be found on the internet. You can find an example for Firefox here.
Troubleshooting#
Should you have problems regarding the authentication the following questions and hints may be of help:
- Compare the time settings in Linux and Windows DC. Are they the same?
- In most cases the server is only accessible via the full FQDN i-doit.mydomain.local.
- Does the i-doit server have access to the domain controller? Is there a firewall between these two?
- Is the SSO domain user unlocked?
- Can the DC be resolved per DNS from the i-doit server?
- Does the web server have read permission for the krb5.keytab file?
