h-inventory#
With h-inventory, you automatically inventory hardware, software, and entire networks. The open-source software is available on SourceForge at http://sourceforge.net/projects/h-inventory/ for various operating systems.
i-doit imports the data exported by h-inventory in XML format and adopts all CMDB-relevant information. This allows you to quickly build a data foundation that you can then further enrich manually.
The following data can be imported from h-inventory:
Attributes and categories
Configuration#
Before importing, configure the interface under Administration → Import and Interfaces → H-Inventory → Configuration. In the Object Matching Profile parameter, you define how already documented objects are identified. Recognized objects are updated during import instead of being created as duplicates.
Inventorying a Windows Client#
To scan a Windows client with h-inventory:
  1. Download the H-Inventory package under Extras → CMDB → Import → H-Inventory.
  2. Extract the archive.
  3. Enter the IP addresses to be scanned in the computer.txt file.
  4. Run scan.bat.
XML Import
After the scan is complete, you will find the export as computername-xx.xml in the same directory.
Graphical Import#
To import the scan results via the web interface:
  1. Navigate to Extras → Import → Import.
  2. Upload the XML file.
  3. Select the file from the list of uploaded exports.
  4. Select the object type Client and the import method inventory (for H-Inventory).
  5. Start the import with Next >>.
The imported client is now available in i-doit.
Import via Console#
You can also automate the import. Use the i-doit console utility for this:
  1. Ensure the XML file is accessible on the server.
  2. Start the import via the console.
All parameters and an example call are available via the --help option.
