Active Directory Documentation#
The "Active Directory Documentation" add-on was designed and created as the first add-on with the Add-on Packager. The Active Directory Documentation add-on is designed to make it easier for administrators to document Microsoft environments. The add-on creates the necessary object types and categories.
Installation and License
The "Active Directory Documentation" add-on is installed like any other add-on via the Admin Center. The add-on does not require a license. However, it can only be used with the pro variant.
Contents of the add-on#
The "Active Directory Documentation" add-on brings a collection of object types, categories and Dialog+ entries.
Two new object type groups "Active Directory" and "Windows Systems" are created with the new object types:
Active directory Windows Systems
Domain DHCP Server
Forest DNS Server
Site Windows client
Certificate authority Window server
In the following, the individual object types with the newly delivered categories are briefly explained.
Domain#
The delivered object type "Domain" allows to document the most common information of a domain.
The following categories are delivered with the object type:
Category
Domain information
Domain schema
Domain structure
FSMO roles
Domain trusts
Assigned domain controller
Directory partitions
Assigned sites
Domain
Forest#
The new object type makes it possible with the supplied categories to document all necessary information of a structure.
Category
FSMO roles
Forest information
Forest trusts
Assigned catalogue server
Forest
Certificate authority#
The "Certificate authority" enables the exact documentation of certificates. Here the name-giving object type makes possible to document the issuing certification authority, as well as the issued certificates.
Category
Issued certificates
Zertifizierungsstelle
Windows server#
The new object type "Windows Server" is fundamentally based on the object type "Server". Here, however, increased emphasis is placed on the benefit and its relationships to the Active Directory.
Category
Domain controller
FSMO information
Global catalogue
LDAP
NTFS shares
Server roles
Windows services
Windows events
Windows features
Windows information
Windows server group
Windows update
Windows client#
The new object type "Windows client" is fundamentally based on the object type "Client". Here, however, as with the Windows Server, increased emphasis is placed on the benefit and its relationships to the Active Directory.
Category
RDP settings
Windows information
Windows client
DNS server#
The "DNS Server" object type is fundamentally based on the "Windows Server" object type. This enables separate documentation of DNS information. The "DNS Documentation" DNS add-on is available for special DNS documentation.
Kategorie
DNS zone entries
Assigned DNS server
DNS server
DHCP server#
The "DHCP server" object type is fundamentally based on the "Windows Server" object type. This enables separate documentation of DHCP information.
Category
DHCP zones
Assigned DHCP server
DHCP server
Changelog
Version Date Changelog
0.1 26.01.2021 Initial Release
