SHD SM-VIEW Connect
This module requires the SM-VIEW Client as a base module.
Installation#
The current version of the SM-VIEW Connect add-on can be downloaded from the following link: https://www.sm-view.de/
A list of the different versions including their changelog can be viewed at the following link: SM-VIEW Connect Modul
Once you have downloaded the add-on, you can easily upload and install it via the i-doit administration interface.
To the documentation of the add-on
