Docker Installation#
i-doit can be fully operated in Docker containers. Two installation paths are available — either with the official container images from the i-doit group (recommended, fastest path) or with self-built containers based on a chosen Linux distribution.
Requirements#
  • Docker ≥ 24 with the Compose plugin (docker compose)
  • Root privileges or sudo access
  • Internet connection (for Docker images and, where applicable, i-doit download)
  • Linux server or Docker-capable host
Installation paths#
Prebuilt stack of two hardened containers (app with Apache + PHP + i-doit, db with MariaDB). The images are provided publicly by the i-doit group — no image build required, faster setup, integrated healthchecks. Optionally extended by nginx for TLS termination.
Container Image Purpose
app registry.on.ops.docupike.net/i-doit/app:39 Apache + PHP + i-doit
db registry.on.ops.docupike.net/i-doit/db:39 MariaDB
nginx (optional) nginx:1.27-alpine TLS reverse proxy
→ Installation with official images
With custom image build#
Classic setup with a self-built PHP-Apache image (php:8.4-apache), a separate MariaDB, and a dedicated cron container. Full control over PHP extensions and Apache configuration.
idoit-web php:8.4-apache (custom build) Apache + PHP + i-doit
idoit-db mariadb:10.11 Database
idoit-cron php:8.4-apache (custom build) i-doit cron jobs
Choose your operating system:
