Manual installation#
With manual installation, you configure all components (Apache, PHP, MariaDB) yourself. This gives you full control over the setup and is the right choice for custom requirements or Windows Server environments.
Prerequisites#
  • The system requirements must be met. The LAMP stack (Apache Web Server, MariaDB/MySQL, PHP) mentioned there is excluded.
  • One of the supported GNU/Linux operating systems is installed and updated.
  • The system can access package repositories via an internet connection.
  • The Apache module (mod_php) is used. Alternative methods (Fast CGI, HHVM) are not covered.
  • Furthermore, this is a simplified setup: i-doit is the main application on the system, and Apache Web Server, PHP, and MariaDB/MySQL are installed locally.
  • Firewall rules and open ports: i-doit is a typical web application. This means that the basic functionality is accessed via a web browser. This typically happens over port 80 (unencrypted) or 443 (encrypted). If a firewall is in use, these ports must be opened for incoming TCP connections. If additional functions are used (notifications, interfaces to third-party applications), additional rules may be required. Communication between i-doit and MySQL/MariaDB takes place locally (port 3306 TCP), for which no separate firewall rules are usually needed.
  • Security frameworks: If a security framework such as AppArmor or SELinux is installed, it must be configured accordingly.
Next Steps#
The exact steps depend on the chosen operating system:
