Red Hat Enterprise Linux 10 Tested with i-doit 38 and Red Hat Enterprise Linux 10 (Coughlan)
Red Hat Subscription required
Installing RHEL packages and activating the CRB repository requires an active Red Hat Subscription . A free Developer Subscription is available at developers.redhat.com .
We explain which packages need to be installed and configured in a few steps in this article.
System Requirements The general system requirements apply. To determine which version is in use, you can run the following command in the console:
The system architecture should be x86 in 64-bit:
x86_64 means 64-bit, i386 or i686 means only 32-bit.
Package Installation On an up-to-date system, the following will be installed:
the Apache HTTP Server 2.4, the scripting language PHP-FPM 8.3, the database management system MariaDB 10.11, and the caching server memcached First, packages are updated from the standard repositories:
For some packages, EPEL is required. On RHEL, EPEL is not available as a package but is installed directly from fedoraproject.org:
sudo dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-10.noarch.rpm -y
The CRB repository (CodeReady Builder) is enabled via the Subscription Manager:
sudo subscription-manager repos --enable codeready-builder-for-rhel-10-x86_64-rpms
Installation of additional packages:
sudo dnf install -y httpd httpd-tools mariadb-server mariadb memcached unzip sudo moreutils php php-fpm php-bcmath php-cli php-common php-curl php-gd php-json php-ldap php-mbstring php-mysqlnd php-opcache php-pdo php-pgsql php-process php-soap php-xml php-zip
To ensure that the Apache HTTP Server, MariaDB, PHP-FPM, and memcached are also started at boot, the following commands are required:
sudo systemctl enable httpd mariadb php-fpm memcached
Then the services are started:
sudo systemctl start httpd mariadb php-fpm memcached
Furthermore, the standard HTTP port 80 is allowed through the firewall. The firewall must be restarted after the adjustment:
sudo firewall-cmd --permanent --add-service= http
sudo systemctl restart firewalld.service
If you want to use i-doit via HTTPS, you need to create a corresponding VirtualHost configuration for port 443. This is not covered here.
Configuration The installed packages for Apache HTTP Server, PHP, and MariaDB already come with configuration files. It is recommended to store custom settings in separate files rather than modifying the existing configuration files. The default configuration settings are supplemented or overridden by the custom ones.
PHP Configuration First, a new file is created and populated with the required settings:
sudo nano /etc/php.d/i-doit.ini
This file receives the following content as specified by us. For more information about the parameters, visit PHP.net
21 allow_url_fopen = Yes
file_uploads = On
max_execution_time = 300
max_file_uploads = 42
max_input_time = 60
max_input_vars = 10000
memory_limit = 256M
post_max_size = 128M
register_argc_argv = On
short_open_tag = On
upload_max_filesize = 128M
display_errors = Off
display_startup_errors = Off
log_errors = On
default_charset = "UTF-8"
default_socket_timeout = 60
date.timezone = Europe/Berlin
session.cookie_lifetime = 0
mysqli.default_socket = /var/lib/mysql/mysql.sock
The memory_limit must be increased if needed, e.g., for very large reports or extensive documents. The value (in seconds) of session.gc_maxlifetime should be greater than or equal to the Session Timeout in the system settings of i-doit. The date.timezone parameter should be adjusted to the local time zone (see list of supported time zones ).
Apache HTTP Server Configuration The Welcome Page is deactivated by renaming:
sudo mv /etc/httpd/conf.d/welcome.conf{ ,.bak}
sudo touch /etc/httpd/conf.d/welcome.conf
Now a new Virtual Host is created for i-doit:
sudo nano /etc/httpd/conf.d/i-doit.conf
This file receives the following content:
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105 <VirtualHost *:80 >
ServerName idoit.example.com
ServerAdmin webmaster@example.com
DocumentRoot /var/www/html
ErrorLog /var/log/httpd/idoit_error.log
CustomLog /var/log/httpd/idoit_access.log combined
<Directory /var/www/html/ >
AllowOverride None
Options -Indexes +SymLinksIfOwnerMatch
<IfModule mod_authz_core.c >
RewriteCond %{REQUEST_METHOD} =GET
RewriteRule "^$" "/index.php"
<Files "*.yml" >
Require all denied
</Files>
<FilesMatch "^\." >
Require all denied
</FilesMatch>
<FilesMatch "^(controller|.*\.sh)$" >
Require all denied
</FilesMatch>
<Files "*.php" >
Require all denied
</Files>
<FilesMatch "\.php\.\d+$" >
Require all denied
</FilesMatch>
<FilesMatch "^(index\.php|controller\.php|proxy\.php)$" >
<IfModule mod_auth_kerb.c >
Require valid-user
</IfModule>
<IfModule !mod_auth_kerb.c >
Require all granted
</IfModule>
</FilesMatch>
<FilesMatch "^(jsonrpc\.php|mcp\.php)$" >
Require all granted
</FilesMatch>
<FilesMatch "^(rt\.php|barcode_window\.php|barcode\.php)$" >
Require all granted
</FilesMatch>
<FilesMatch "^(qr\.php|qr_img\.php)$" >
Require all granted
</FilesMatch>
<FilesMatch "^js\.php$" >
Require all granted
</FilesMatch>
</IfModule>
<IfModule mod_alias.c >
RedirectMatch 403 /imports/.* $
RedirectMatch 403 /log/.* $
RedirectMatch 403 /temp/.* (?<!\.(css|xsl))$
RedirectMatch 403 /upload/files/.* $
RedirectMatch 403 /upload/images/.* $
RedirectMatch 403 /vendor/.* $
</IfModule>
<IfModule mod_expires.c >
ExpiresActive On
ExpiresByType image/svg+xml A2592000
ExpiresByType image/gif A2592000
ExpiresByType image/png A2592000
ExpiresByType image/jpg A2592000
ExpiresByType image/jpeg A2592000
ExpiresByType image/ico A2592000
ExpiresByType text/css A2592000
ExpiresByType text/javascript A2592000
ExpiresByType image/x-icon "access 1 year"
ExpiresDefault "access 2 week"
<IfModule mod_headers.c >
Header append Cache-Control "public"
</IfModule>
</IfModule>
<IfModule mod_rewrite.c >
RewriteEngine On
RewriteCond %{HTTP:Authorization} .+
RewriteRule ^ - [E=HTTP_AUTHORIZATION:%0]
RewriteRule favicon\.ico$ images/favicon.ico [L]
RewriteCond %{REQUEST_FILENAME} !-l
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule .* index.php [L,QSA]
</IfModule>
<Files "*.ini" >
Require all denied
</Files>
</Directory>
TimeOut 600
ProxyTimeout 600
<FilesMatch "\.php$" >
<If "-f %{REQUEST_FILENAME}" >
SetHandler "proxy:unix:/run/php-fpm/www.sock|fcgi://localhost"
</If>
</FilesMatch>
</VirtualHost>
i-doit ships custom Apache settings in files named .htaccess . These must be reviewed after each update and updated in the VirtualHost configuration.
In the next step, the Apache HTTP Server is restarted:
sudo systemctl restart httpd php-fpm
For Apache to have read and write permissions in the future i-doit installation directory, this must be allowed by SELinux :
sudo chown apache:apache -R /var/www/html
sudo semanage fcontext -a -t httpd_sys_rw_content_t "/var/www/html(/.*)?"
sudo restorecon -Rv /var/www/html
MariaDB To ensure MariaDB delivers good performance and can be operated securely, a few steps are needed that should be carried out meticulously. This starts with a secure installation. The recommendations should be followed . The root user should receive a secure password:
Do not enable socket authentication for the root user, as this would prevent i-doit from connecting to the database.
sudo mysql_secure_installation
Then MariaDB is set to slow shutdown :
mysql -u root -p -e"SET GLOBAL innodb_fast_shutdown = 0"
A new file is created for the custom configuration settings:
sudo nano /etc/my.cnf.d/99-i-doit.cnf
This file contains the new configuration settings. For optimal performance, these settings should be adjusted to the (virtual) hardware :
19 [mysqld]
innodb_buffer_pool_size = 1G
innodb_log_file_size = 512M
innodb_sort_buffer_size = 64M
sort_buffer_size = 262144 # default
join_buffer_size = 262144 # default
max_allowed_packet = 128M
max_heap_table_size = 32M
tmp_table_size = 32M
max_connections = 200
innodb_file_per_table = 1
innodb_lru_scan_depth = 2048
table_definition_cache = 1024
table_open_cache = 2048
table_open_cache_instances = 8
innodb_stats_on_metadata = 0
sql-mode = ""
Finally, MariaDB is restarted:
sudo systemctl restart mariadb.service
Finally, we need to configure SELinux so that Apache can access the network and the database:
# Allow Apache to connect to the database
sudo setsebool -P httpd_can_network_connect_db 1
# Allow Apache to connect to the network
sudo setsebool -P httpd_can_network_connect 1
# Allow Apache to connect to unusual pgsql Port for JDisc
sudo semanage port -a -t postgresql_port_t -p tcp 25321
The last command is only needed if you plan to connect JDisc . SELinux otherwise blocks php-fpm from connecting to the PostgreSQL port 25321 of JDisc (name_connect on tcp_socket), so the port is assigned to the postgresql_port_t type here. Without JDisc you can skip it.
Next Step The operating system is now prepared so that i-doit can be installed:
Continue to Setup
October 9, 2026 January 31, 2023
