Back Up and Restore Data#
The IT documentation contains business-critical data -- network diagrams, contract information, credentials, and configurations. Data loss due to hardware failure, human error, or an attack can have serious consequences. That is why i-doit belongs in every backup strategy.
Three areas need to be backed up:
  1. Databases -- system and tenant database(s)
  2. Files -- the i-doit installation directory including uploaded documents
  3. System configuration -- Apache, PHP, MariaDB
Easiest way: system:tenant-export
Since i-doit v35, the console command system:tenant-export is available, which exports the database and files in a single step as a ZIP. For regular automated backups, this is the recommended method.
Since version 35, the i-doit console offers the commands system:tenant-export and system:tenant-import. They export or import a complete tenant -- database and uploaded files -- in a ZIP package. This is the simplest and safest way for a complete backup.
Export (Create Backup)#
sudo -u www-data php /var/www/html/console.php system:tenant-export \
    --user admin --password admin --tenantId 1
This creates a ZIP archive in the i-doit directory containing both the database dump and all uploaded files.
Import (Restore Backup)#
sudo -u www-data php /var/www/html/console.php system:tenant-import \
    --file /path/to/backup.zip \
    --tenant-database-name idoit_data \
    --tenant-title "My Tenant" \
    --db-root-user root \
    --db-root-pass secret \
    --db-host localhost
Options:
parameter Description
--file Path to the ZIP file from the export
--tenant-database-name Name of the tenant database
--tenant-title Display name of the tenant
--with-system-settings Also import system-wide settings
--with-tenant-settings Import tenant-specific settings
--db-root-user / --db-root-pass Database root credentials (needed to create the database)
--db-host / --db-port Database host and port (default: localhost:3306)
Set Up as Cronjob#
For daily automatic backups:
# Export tenant daily at 02:00
0 2 * * *  php /var/www/html/console.php system:tenant-export --user admin --password admin --tenantId 1 > /var/www/html/log/tenant-export.log 2>&1
Store backups externally
A backup that only exists on the same server does not protect against hardware failures. Copy the ZIP files regularly to an external system -- via rsync, scp, or to a network share.
Manual Backup#
If you are running an older i-doit version or need more control over the backup process, you can also back up the database and files manually.
Back Up Databases#
Use mysqldump for the database export. During the backup, no one should be working with i-doit -- it is best to stop the web server:
# Stop web server
sudo systemctl stop apache2
# Back up all i-doit databases
mysqldump -hlocalhost -uroot -p --all-databases | gzip -9 > /backup/idoit_$(date +%F).sql.gz
# Start web server again
sudo systemctl start apache2
Also disable cronjobs during the backup.
Restore:
gunzip < /backup/idoit_2026-04-07.sql.gz | mysql -hlocalhost -uroot -p
Foreign Key Constraints
During restoration, MariaDB may abort with errno: 150 "Foreign key constraint is incorrectly formed". This happens because tables are restored individually and references to tables that do not yet exist are encountered.
Solution: Drop the databases before restoration:
DROP DATABASE idoit_system;
DROP DATABASE idoit_data;
Back Up Files#
Back up the entire i-doit directory:
tar -czf /backup/idoit_files_$(date +%F).tar.gz /var/www/html/
Restore:
tar -xzf /backup/idoit_files_2026-04-07.tar.gz -C /
Then check the file permissions:
sudo chown -R www-data:www-data /var/www/html/
Back Up System Configuration#
Back up the configuration files for Apache, PHP, and MariaDB:
tar -czf /backup/idoit_config_$(date +%F).tar.gz \
    /etc/apache2/ \
    /etc/php/ \
    /etc/mysql/
Ideally, you have already documented and securely stored the customizations during installation.
Backup Script#
For a simple, automated backup you can use a bash script. An example can be found at Backup script for data and files.
Recommendation
For new installations (from v35 onwards), system:tenant-export as a cronjob is the simpler and more reliable solution because the database and files are backed up in a consistent package.
VM Snapshots#
i-doit often runs on a virtual machine. However, a snapshot during live operation is not a reliable backup -- the database holds data in memory that may not have been written to disk at the time of the snapshot.
If you want to use snapshots, stop the database first:
# Before the snapshot:
sudo systemctl stop mysql
# After the snapshot:
sudo systemctl start mysql
VM snapshots are a good supplement but not a substitute for a regular backup.
Best Practices#
  • Regularity -- back up daily, at minimum before every update
  • Test restores -- a backup is only as good as the last successful restore test. Regularly restore on a test system
  • Store externally -- backups do not belong on the same server. Copy them to a network share, a backup server, or encrypted to the cloud
  • Encrypt -- when backups leave the premises, encrypt them (e.g., with gpg). Your CMDB contains sensitive infrastructure data
  • Retention period -- keep multiple generations (e.g., 7 daily backups + 4 weekly backups) so you can restore older states as well
  • Document -- record the restore process in writing so that colleagues can also perform a recovery in an emergency
For a complete migration to another server, read the article Migrating an installation on Linux.
