Update PHP (Debian/Ubuntu)#
PHP security update November 2026
On November 19, 2026, the PHP project released PHP 8.5.13, 8.4.28, 8.3.37 and 8.2.36. They fix about 20 vulnerabilities, the most severe one rated critical (CVE-2026-115560, remote code execution via session handling).
This vulnerability only applies to an unusual configuration with mixed session serializers. i-doit does not use this configuration, so a standard installation is practically not exploitable. The other fixes concern PHP-FPM, Session, Phar and SOAP, among others.
Install the update as usual with your distribution's packages and restart PHP-FPM and the web server afterwards. The procedure is the same as for the PHP security update of October 2026, including Windows. Until the update is installed, you can additionally set session.upload_progress.enabled = 0 in php.ini or in the FPM pool and restart PHP-FPM.
New PHP versions bring security fixes, better performance, and new features. At the same time, i-doit requires specific PHP versions -- always check the system requirements before updating to see which versions are currently supported.
This article describes switching from one PHP version to a newer one on Debian and Ubuntu -- using official package sources without third-party repositories.
Backup first
Before the PHP update, create a complete backup -- at minimum of the Apache configuration (/etc/apache2/), the PHP configuration (/etc/php/), and your i-doit installation.
Quick Guide (TL;DR)#
Using the example of switching from PHP 8.2 to PHP 8.3 with PHP-FPM:
- Create a backup
- Install new packages:
1sudo apt install libapache2-mod-fcgid php8.3-{bcmath,cli,common,curl,fpm,gd,imagick,ldap,mbstring,memcached,mysql,pgsql,soap,xml,zip} - Start and enable PHP-FPM:
1sudo systemctl enable --now php8.3-fpm - Create the i-doit PHP configuration for the new version:
1sudo nano /etc/php/8.3/mods-available/i-doit.inii-doit.ini 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
allow_url_fopen = Yes file_uploads = On max_execution_time = 300 max_file_uploads = 42 max_input_time = 60 max_input_vars = 10000 memory_limit = 256M post_max_size = 128M register_argc_argv = On short_open_tag = On upload_max_filesize = 128M display_errors = Off display_startup_errors = Off error_reporting = E_ALL & ~E_DEPRECATED & ~E_STRICT log_errors = On default_charset = "UTF-8" default_socket_timeout = 60 date.timezone = Europe/Berlin session.gc_maxlifetime = 604800 session.cookie_lifetime = 0 mysqli.default_socket = /var/run/mysqld/mysqld.sock1sudo phpenmod -v 8.3 i-doit - Switch the Apache VirtualHost to the new PHP version -- adjust the socket path in
/etc/apache2/sites-available/i-doit.conf:1SetHandler "proxy:unix:/run/php/php8.3-fpm.sock|fcgi://localhost/" - Enable Apache modules and restart services:
1 2
sudo a2enmod proxy_fcgi setenvif rewrite sudo systemctl restart php8.3-fpm apache2 - Clear the i-doit cache under Administration > System Repair and Cleanup
Which PHP Version Does My Distribution Provide?#
You can only install the PHP version that your distribution offers in its official repositories. For a newer version, you would need to upgrade the distribution itself.
| Distribution | PHP Version |
| Debian 12 "Bookworm" | PHP 8.2 |
| Ubuntu 22.04 LTS "Jammy" | PHP 8.1 |
| Ubuntu 24.04 LTS "Noble" | PHP 8.3 |
Check which version is available:
1 | |
Preparations#
1. Update the System#
1 | |
2. Determine the Current PHP Version#
1 2 3 4 5 6 7 8 | |
3. Check the Apache Integration Method#
There are two ways Apache processes PHP files:
| Method | Description | Recommendation |
| mod_php | PHP runs directly in the Apache process. Simple but less performant. Requires mpm_prefork. | For small installations |
| PHP-FPM | PHP runs as a separate service. Apache forwards requests via a socket. Allows mpm_event. | Recommended for production |
Check which method is currently active:
1 2 3 4 5 | |
Install PHP Packages#
Install the packages for the new version. In the following example, PHP 8.2 is replaced by PHP 8.3 -- adjust the version numbers to your situation.
1 | |
If you use mod_php instead of PHP-FPM, also install:
1 | |
Migrate PHP Configuration#
Do not copy the old php.ini
Each PHP version may have changed or removed directives. Transfer your customizations manually to the new configuration.
Create the i-doit Configuration#
The cleanest approach: create a dedicated .ini file with the i-doit-specific settings:
1 | |
| i-doit.ini | |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 | |
Enable the configuration for all SAPIs (CLI and FPM):
1 | |
The complete settings can be found at System settings.
Where Are the php.ini Files Located?#
| SAPI | Path |
| CLI | /etc/php/8.3/cli/php.ini |
| Apache (mod_php) | /etc/php/8.3/apache2/php.ini |
| PHP-FPM | /etc/php/8.3/fpm/php.ini |
Configure Apache#
Option A: PHP-FPM (Recommended)#
1. Ensure mod_php is disabled:
1 2 | |
2. Enable Apache modules for FPM:
1 | |
3. Switch MPM to event (better performance than prefork):
1 2 | |
4. Adjust VirtualHost:
Change the socket path in /etc/apache2/sites-available/i-doit.conf:
| /etc/apache2/sites-available/i-doit.conf | |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 | |
Check the socket path
The path /run/php/php8.3-fpm.sock must match the listen directive in /etc/php/8.3/fpm/pool.d/www.conf. A mismatch is the most common cause of errors.
5. Restart PHP-FPM and Apache:
1 | |
Option B: mod_php#
1. Disable old version, enable new one:
1 2 | |
2. MPM to prefork (mod_php requires this):
1 2 | |
3. Restart Apache:
1 | |
Verify the installation#
Verify PHP Version#
1 2 3 4 5 | |
Check i-doit#
- Open i-doit in the browser and verify that everything works
- Go to Administration > System Repair and Cleanup and clear the cache
- Check the system overview under Administration > System Overview -- there you can see the active PHP version
Remove the Old PHP Version#
If everything works, remove the old version:
1 2 | |
Caution
Before removing, verify that no other service on the server requires the old PHP version.
Common Problems#
HTTP 500 Internal Server Error#
- Check logs:
tail -50 /var/log/apache2/error.logandjournalctl -u php8.3-fpm - Socket mismatch: The most common error -- the path in the VirtualHost does not match the FPM configuration
- Missing modules:
php -mshows which modules are loaded. Compare with the system requirements - File permissions:
www-dataneeds read access to the PHP files - Configuration errors:
apache2ctl configtestchecks the Apache syntax
PHP Code Is Displayed as Text#
Apache is not forwarding .php files to the PHP interpreter:
- With PHP-FPM: Is the
<FilesMatch>block missing in the VirtualHost? - Is the FPM service running?
systemctl status php8.3-fpm - Are mod_php and FPM active at the same time? This causes conflicts -- disable mod_php.
Error Messages About Missing Extensions#
Check the loaded modules and compare with the required ones:
1 | |
Install missing modules:
1 | |
Changes to php.ini Have No Effect#
- Edited the wrong file? CLI, FPM, and mod_php each have their own php.ini files
- Service not restarted? After changes to the FPM configuration:
sudo systemctl restart php8.3-fpm - Custom .ini overridden? Check with
php --iniwhich files are loaded and in what order
