Customer Portal#
There is a central contact point for i-doit users. For example, Installation packages and the currently valid offline token can be downloaded there. The subscription or purchase products (for example add-ons) are also listed. The Customer Portal can be accessed at the following address:
A license token is required for the Add-on & Subscription Center. Customers of i-doit receive the necessary information for the creation of a user account during the ordering process.
After calling https://center.i-doit.com/ you will land on the login page.
After logging in, the dashboard is displayed
Information about the subscription can be found at Subscription
Invoices and invoice details can be viewed under Invoice
Helpful links and a contact form for support can be found at Help
The offline license can be found under Advanced. This is required if the i-doit instance has no internet access.
The Downloads menu item lists all available downloads.
