The i-doit license token is used to authenticate your i-doit instance against the license server and to retrieve your license keys. Without a valid license token you cannot access the Add-on & Subscription Center and your i-doit will not be licensed. You initially receive your license token when evaluating or buying an i-doit subscription. If you do not have access to your license token anymore please follow the instructions below or contact our sales team.
If you have any questions about licensing or contracts, please contact the sales team at
Phone: +49 211 699 31-185
E-mail: sales@i-doit.com
Overview#
I want to retrieve my license token from my running i-doit instance
I can not find my license token and I want to reset it
- How can I reset my token?
- !!! IMPORTANT !!! Activate new token
Variant A: Find my token in the Add-on & Subscription Center? (i-doit version 33 and above)#
Open the Add-on & Subscription Center in i-doit, where the token is displayed in the Advanced tab under "Weblicense Token".
Variant B: Find my token in the Admin-Center? (i-doit version 34 and below)#
Log in to the Admin-Center and then the token is displayed under "Weblicense Token" in the Config menu.
Variant C: Find my token with access to the operating system? (All versions)#
The "Weblicense Token" is stored in the file .../i-doit/src/config.inc.php. You can output the token directly if you adapt this command to your i-doit installation path:
1 | |
The output will then look something like this:
1 2 | |
How can I reset my token?#
If you cannot find the token, click on "Reset token" button below. This will take you to the Reset token page in the Customer Portal. Here you can request a new token. Just follow the instructions on the page.
IMPORTANT: The old token becomes inactive as soon as a new token is generated. You must activate your new token.
Activate new token#
To activate the new token, please use our licensing i-doit instructions.
