Starting with i-doit version 1.7, you need at least MySQL 5.6 or MariaDB 10.0 (previously: MySQL 5.5 / MariaDB 5.5). This article describes the upgrade steps for the various supported operating systems.
Check your current version:
1 | |
The following table shows the recommended upgrade paths per operating system:
| Operating System | Version | Old Database Backend | New Database Backend |
| Debian GNU/Linux | 8 | MySQL 5.5, MariaDB 10.0 | MariaDB 10.0 |
| 7.8 | MySQL 5.5 | MariaDB 10.0 | |
| Ubuntu | 14.04 LTS | MySQL 5.5, MySQL 5.6, MariaDB 5.5 | MySQL 5.6 |
| 12.04 LTS | MySQL 5.5 | MariaDB 10.0 | |
| Red Hat Enterprise Linux (RHEL) | 7.1 | MariaDB 5.5 | MariaDB 10.0 |
| 6.7 | MySQL 5.1 | MariaDB 10.0 | |
| SUSE Linux Enterprise Server (SLES) | 12 | MariaDB 10.0 | MariaDB 10.0 |
| Windows Server | 2008/2012 | Depending on XAMPP version | MariaDB 10.0 |
It is absolutely essential that the data is backed up before changes are made to the system. Since the upgrade procedure can take varying amounts of time depending on the operating system, users of i-doit should be informed in advance.
Debian GNU/Linux 8#
Version 8 of Debian GNU/Linux contains MySQL 5.5 and MariaDB 10.0 in its standard packages. If MySQL is installed, it is sufficient to install the MariaDB package. This will replace MySQL with MariaDB:
1 2 | |
Debian GNU/Linux 7.8#
Version 7.8 of Debian GNU/Linux contains MySQL 5.5 and no MariaDB in its standard packages. To use MariaDB, the official MariaDB repository must be added. Caution: Third-party repositories can affect the system. Installing MariaDB replaces MySQL:
1 2 3 4 5 6 | |
Ubuntu 14.04 LTS#
Version 14.04 LTS of Ubuntu contains MySQL 5.5, 5.6, and MariaDB 5.5 in its standard packages. It is therefore recommended to use MySQL 5.6. If MySQL 5.5 or MariaDB 5.5 were previously installed, they will be replaced by MySQL 5.6:
1 2 | |
Ubuntu 12.04 LTS#
Version 12.04 LTS of Ubuntu contains MySQL 5.5 and no MariaDB in its standard packages. Since this operating system version contains very old packages for MySQL, PHP, and Apache web server, we generally advise against using it and recommend upgrading to version 14.04 LTS. If this is not possible, you can switch to MariaDB 10.0 by adding the official MariaDB repository. Caution: Third-party repositories can affect the system. Installing MariaDB replaces MySQL:
1 2 3 4 5 6 | |
Red Hat Enterprise Linux 7.1#
Version 7.1 of Red Hat Enterprise Linux (RHEL) contains MariaDB 5.5 and no MySQL in its standard packages. To switch to MariaDB 10.0, only a few steps are needed according to a MariaDB blog post. This replaces MariaDB 5.5 with 10.0. Caution: Third-party repositories can affect the system.
This upgrade path refers to the 64-bit variant of the operating system.
First, the existing version is uninstalled:
1 | |
Then the file /etc/yum.repos.d/MariaDB.repo must be created and edited:
1 2 3 4 5 6 7 | |
Finally, the packages are installed, the MariaDB server is started, and the databases are brought up to date:
1 2 3 | |
In some cases, removing the packages mentioned earlier also uninstalls the associated PHP extension. The following commands are needed to reinstall it:
1 2 | |
Red Hat Enterprise Linux 6.7#
Version 6.7 of Red Hat Enterprise Linux (RHEL) contains MySQL 5.1 and no MariaDB in its standard packages. Since this operating system version contains very old packages for MySQL, PHP, and Apache web server, we generally advise against using it and recommend upgrading to version 7.1. If this is not possible, you can switch to MariaDB 10.0 by adding the official MariaDB repository, as described in a MariaDB blog post. Caution: Third-party repositories can affect the system.
1 | |
1 2 3 4 5 6 7 | |
Finally, the package is installed:
1 | |
SUSE Linux Enterprise Server 12#
Version 12 of SUSE Linux Enterprise Server (SLES) already contains MariaDB 10.0 in its standard packages but no MySQL. Therefore, no upgrade is necessary.
Windows Server 2008/2012#
If Windows Server 2008/2012 is used, XAMPP is recommended. This distribution provided by Apache Friends includes, among other things, the Apache web server, PHP, and MariaDB. Care should be taken to always use the current version.
Since XAMPP has neither official documentation nor an update mechanism, the upgrade path may be very complicated and error-prone. A current backup and thorough testing after the upgrade are therefore indispensable.
If a XAMPP version with MariaDB 10.0 is not already in use, the following steps are necessary:
- Copy the XAMPP directory, usually at C:\xampp\
- Download the current version of XAMPP from the official website
- Uninstall the previous XAMPP version
- Delete the XAMPP directory
- Install the new XAMPP version in the same directory
- Restore the htdocs and mysql\data directories from the copy of the XAMPP directory without overwriting existing files
- Adjust configuration files to meet the system settings requirements
- Start Apache web server and MariaDB
- Perform tests
Troubleshooting#
Headers and client library minor version mismatch
After the upgrade, it may happen that i-doit cannot establish a connection to the MySQL/MariaDB server. The following error message appears:
1 | |
The reason for this error lies in still-running Apache processes. The PHP bindings for MySQL/MariaDB (mysqli) are supposed to access the new MySQL/MariaDB interface, but the old interface is still in memory. Restarting Apache resolves this. Example on Debian/Ubuntu:
sudo service apache2 restart
