Custom Translations#
Using custom translations, you can change the labels of desired fields or add new languages with just a few mouse clicks.
Creating a Language#
  • Navigate to Administration > Data View > Language Profiles
  • Click New to create a new language
  • Enter the language, select a flag, and click Save
Creating a language
You can now select the language in i-doit, but it is still identical to the German language.
Therefore, you now need to translate the fields.
Translating a Field#
As an example, we change the label of the Quickpurge button.
Translating a field
  • Select the language and click edit
  • Filter for Quickpurge and enter the translation
Translating a field
  • Save, navigate to the overview, and switch the language to Spanish
Translating a field
