i-doit with OpenID-Connect authentication explained with Google login#
Requirements#
  • Debian 10
  • installed i-doit
  • Server needs internet access
  • Server needs a valid DNS name
  • Server has to be reachable via SSL
  • Access to Google APIs & Dienste
Create OAuth login credentials
Open https://console.developers.google.com/
  1. Go the the home screen
  2. Select "Credentials"
  3. Select "Create Credentials"
  4. Select "OAuth client ID"
openid-connect
  1. Select "Web application"
  2. Use a recognizable title for the name
  3. Specify as Authorized Redirection URL a URL that is behind the web resource to be backed up but does not point to any content (!).
    The URL specified here as an example should be secured with authentication from https://gauth.i-doit.com/i-doit/.
    The attached resource "redirect_uri" does not exist on the web server!
openid-connect
  1. Copy Client ID (will be needed later)
  2. Copy Client Secret (will be needed later)
  3. Configure OAuth approval screen
    (This is not neccessary for a test but will be needed on live systems)
openid-connect
Configure webserver
Install the Apache package mod_auth_openidc in your installation of Debian 10#
sudo apt install libapache2-mod-auth-openidc
Add the following code to your Apache configuration:#
22
23
OIDCProviderMetadataURL https://accounts.google.com/.well-known/openid-configuration
OIDCClientID <Client_ID_aus_der_Google_API_Console>
OIDCClientSecret <Client_Secret_aus_der_Google_API_Console>
# OIDCRedirectURI ist die vorher angegebene Redirect URL, die auf einen nicht
# existierenden Content zeigt, der hinter der abgesicherten URL liegt
OIDCRedirectURI https://<SERVER-URL>/i-doit/redirect_uri
OIDCCryptoPassphrase <Irgendein_Passwort_definieren_für_die_Verschlüsselung>
OIDCProviderIssuer accounts.google.com
OIDCProviderAuthorizationEndpoint https://accounts.google.com/o/oauth2/auth
OIDCProviderTokenEndpoint https://accounts.google.com/o/oauth2/token
OIDCProviderTokenEndpointAuth client_secret_post
OIDCProviderUserInfoEndpoint https://www.googleapis.com/plus/v1/people/me/openIdConnect
OIDCProviderJwksUri https://www.googleapis.com/oauth2/v2/certs
OIDCRemoteUserClaim email
OIDCScope "email"
<Location /i-doit/>
    AuthType openid-connect
    Require valid-user
</Location>
This is how the configuration looks:#
openid-connect
Restart your webserver#
Test authentication and finish last steps#
Create the file identity.php. In our case it will be created at /var/www/html/i-doit/identity.php.
<?php
echo $_SERVER['REMOTE_USER'];
#print_r(array_map("htmlentities", apache_request_headers()));
  1. Open the file in your browser
  2. Login via Google
openid-connect
  1. Verify the displayed ID (This should be the ID from the e-mail address)
  2. Login into your i-doit and use this as the login name for the corresponding i-doit user
    (!) Important: The domain part of the address, beginning with @ is not used. The name has to be reduced to the first part:“testaccount@i-doit.com” becomes “testaccount”.
openid-connect
openid-connect
Enable SSO in i-doit
  1. Open your i-doit administration
  2. Select system settings
  3. Select "yes" at "Single Sign on" option "Active"
  4. Save
openid-connect
Done! If i-doit is now opened, the Google authentication appears first. After successful authentication, the user is directly logged in with the account linked to the user name.
