Managing Passwords#
As a system administrator, you handle dozens of passwords every day. i-doit comes with a simple password management feature that keeps your head clear and helps you find needed credentials quickly.
Distinction from Password Managers#
i-doit is not a full-fledged password manager like KeePass. The motivation: to keep credentials as close to the IT documentation as possible so you can find them quickly and easily in an emergency.
If you prefer to continue using a dedicated password manager, set links to the corresponding entries via the Access category. This keeps the credentials just a few clicks away.
Category Passwords#
Any number of credentials can be stored per object. The category Passwords is designed for this purpose. The data is stored encrypted in the respective tenant database of i-doit.
List of entries in the Passwords category
Attribute Description
Label Concise label for the entry
Username Name of the user
Password Password of the user
Form in the Passwords category
