Integrated Authentication#
Backup notice
Please create a complete backup before making any changes to an interface or import. If the result is not satisfactory, the backup can be easily restored.
Overview#
i-doit offers a flexible selection of authentication methods tailored to different use cases and security requirements. This page gives you an overview of the available options from simple local login through connection to a central Active Directory to advanced methods such as Single Sign-On (SSO) or Two-Factor Authentication (2FA).
Local Users#
Local users are managed directly in i-doit as objects of type "Person" and are immediately ready for use. Their greatest strength is serving as an independent emergency access in case central authentication systems such as LDAP/AD are temporarily unavailable.
Further links:
LDAP / Active Directory#
i-doit supports seamless integration with directory services such as LDAP or Active Directory. This enables:
- Central authentication during web login via the existing corporate account.
- Automated import of users and groups (optionally via console).
Additional information:
API Access (JSON-RPC)#
For process automation and connecting external tools, i-doit provides a powerful JSON-RPC API. A local user with a valid API key is required per tenant.
Advanced Authentication Methods#
To further increase convenience and security, i-doit supports modern authentication methods:
- Single Sign-On (SSO): Reduces login barriers for users via SAML or Kerberos and increases convenience.
- Two-Factor Authentication (2FA): Adds a second security layer to the login and effectively protects accounts from unauthorized access.
Conclusion#
Local users enable immediate access and serve as emergency login. LDAP/AD provides central management for larger teams. The API is the key to automation and integration. SSO and 2FA increase convenience and security in enterprise environments.
