Builtin authentication#
Work in Progress
Here we describe which login options are already integrated in i-doit pro.
Login via the web interface is possible via LDAP or local user.
If you are using the i-doit pro Add-on API, you need a local user for authentication.
Also you need the API Token, which is for identify the tenant you want to login.
